If the lamp in coloured yellow/
amber the examiner will need to
obtain evidence from the vehicle
driver that the MIL became
illuminated during this journey
We have a couple of trailors that are “not compatable with the unit” and have the amber ABS light showinghow does that work then.i.e should they be made compatable
should you ignore it
is the “not compatable” just BS
gezt:
I’ve also been told this in the past. No idea if it’s true or not.
I know it’s possible to corrupt / surge spike the trailer ABS computer by connecting with the ignition on, so maybe this is more the issue?
waynedl:
We used to have a lot of amber abs warnings for that reason, now we are advised to connect with the ignition off. Since adopting the “ignition off” approach, I haven’t had an amber light at connection for over 12 months.
Dads old place had a tanker and when you hooked up to the stralis every single warning possible went off and when you hooked it up to the fh16 everything went quiet again
Rules must have changed since I worked over there. If an amber ABS warning light came on during your pre-trip check you could note it and carry on, lots of trailers were not compatible with certain trucks and in any case working ABS was not a legal requirement, it just was advised to get it repaired at the next available chance. ABS on trailers didn’t really appear untill late 80’s and after that I would rather drive without ABS than wih it.
The rules I just mentioned still apply here, I have been stopped by DOT at an inspection site and so long as I pointed out the warning light before they saw it I was allowed to over look it without a ticket, if however I had denied the light was on and they saw it I would have got a ticket.
gezt:
Yeah, i’ve been told this too . . sort of!
I’ve been told, everything works fine but it shows as not being compatible on the dash. To be fair, of all our trailers it’s always the same type that show the fault.
I had a bus thta had the ABS light on, STOP on the dashboard warning and an alarm going off in the cab.
Engineers said “carry on driver, OK to drive”.
I refused to drive the bus.
Imagine if you had a crash, VOSA would be all over you!!!
However, my understanding is that if ABS packs up, braking goes back to normal.
rambo19:
Indeed,it say’s in the premium handbook(pretty sure it does) that if you get all these pretty lights then the braking reverts to conventional but greater pedal pressure may be required…Ah,that would bring back memories of the wonderful brakes on older scanias.
Coffeeholic:
I generally cover the amber light with something and crack on. Can’t see the problem = no problem.
This seems a logical sugestion
I had something similar with the amber ‘Check engine’ light on my old truck, it was on for months and every time the mechanics put it on the lap top it showed various faults, not to serious, each time I started the engine the light came on and stayed on untill the tiny lamp blew out… Fixed then
If you do get pulled by VOSA while you have an ABS light lit a trick is to stop the engine as soon as you stop, as on some trailers the light only goes off once you do a certain speed, something like 15kmh. They know this though and try to get in your door to look at dash before you stop engine
