Messrs Corbishley have restored KCH to a high standard and given us a lot of pleasure at shows (see pic by me below, taken on their premises). However, there’s nowt wrong with dreaming about alternative options for any restored wagon. I’ve given it a bit of thought over recent years but I must admit it never occurred to me to consider a wrecker option as shown by the modeller above.
Had KCH been a standard 4x2 unit it would have made a perfect candidate for a unit and TIR-tilt restoration in say, Eric Vick livery and been given a visor and Kysor to finish the job off. However, KCH’s unusually long wheelbase and double-drive make it an unlikely candidate for such a restoration.
Restoring it to Eyckmans livery and returning it to tractive unit status would be the most logical and the purest form of restoration. It was one of only three 6x4 conversions (Cauvas and Shamara were the others) but had a longer wheelbase than the other two so dressing it up as either of those two would be unrealistic. The Eyckmans livery is perfect for an accurate restoration using an original Eyckmans vehicle. You could remove the box and add a Fassi crane (a non-functional one would do). The stabilisers fore and aft might be expensive and tricky but would add authenticity. Then to complete the equipage, add a period pole trailer.
Another idea would be to restore it to Eyckman’s Belgian colours, add a visor (but not replace the crane), and put a classic 10m period Belgian pitch-roofed coiler spread-axle trailer on the back in the same colours. This would work perfectly as the wheel-base of the 3-axle unit I used to pull them was exactly the same (long) because in the early ‘80s there were plenty of units with hastily added rear axles to cope with new 38-tonne legislation (see pic of the one I drove below).
Another possibility is to use it as a 6x4 tractor with a low-loader. That would be perfectly feasible and legit.
Moving into the fantasy area, there is a number of things you could do with this wagon if you were prepared to create an NGC which didn’t exist in real life (like KCH is now, don’t forget).
For example, the lorry almost certainly has a long enough wheelbase for a container skelly frame and 20-foot container. Just add Jost-type coupling and an A-frame skelly trailer. This would be expensive but effective. It would also take up space. If it were un-sign-written it could effectively be done up as a M/E drawbar with the usual Kysor & visor, TIR-plates etc. For that matter, it could even be done up as drawbar TIR-tilt.
If you were prepared to play about with the truth a bit, you could dress it up in visor and Kysor and paint it in one of liveries of operators of NGCs on Middle-East work (Eric Vick, Richard Read, Vijore, Trans Arabia, Beresford, ERF demo, etc). The only things that would stand out are the long wheelbase and the double-drive. The long wheelbase issue would evaporate if it had a low-loader with an ‘open-TIR’ cargo (and plenty like that went down to the Gulf). This pic was photo-shopped by me in ‘paint’ about 4 years ago.
Robert
