You can beat a speed camera ............But
If you want to avoid a speeding fine then don’t speed - simple. But it seems there may be another way to avoid getting snapped by a speed cameras.
Physics students at the University of Leicester have discovered that you can escape detection if you drive past a speed camera very, very fast. So fats that the camera does not see your number plate.
So what’s the catch? Well it seems that for this trick to work, you’d need to be travelling at one sixth the speed of light, or 119 million miles per hour.
pocketgpsworld.com/How-fast- … a-4714.php
Top Gear did it at a slightly more attainable 174mph, in a TVR Tuscan.
cracker-bar:
not in a thirty though! :sunglasses:
That’s not quite the same thing.
Top Gear did it with a Gatso camera. The camera went off but the car was out of range if the camera when the photo was taken.
This report is about the camera not detecting the “vehicle”
Tipper Tom:
So do I have to take the limiter off?
You probably want to whip the fuse out yeah
I’m guessing you’ll need a downhill run. With a loaded trailer.
yeah like driving over the edge of a tall mountain fully loaded or something :smiley: :smiley:
GBD:
but isn`t terminal velocity in free fall only 120mph ? :confused:
peirre:
GBD:
Felix Baumgartner (German: [felɪks baʊmɡaːɐtnəʁ]; born 20 April 1969) is an Austrian skydiver, daredevil and BASE jumper.[1] He set the world record for skydiving an estimated 39 kilometres (24 mi), reaching an estimated speed of 1,357.64 km/h (843.6 mph), or Mach 1.25
bit faster than 120
yes you can beat a speed camera, you can beat it by not speeding or going on a route where there are no speed cameras
10mm HSS metal drill bit in a cordless drill and a can of expanding foam does the trick :wink:
jamiep1988:
peirre:
GBD:
bit faster than 120
served in 2 REP :grimacing: with felix! :laughing: in the French foreign legion! :sunglasses: mad as a box of frogs that other mucker! :wink:
