Lee, have you got an anderson connection behind your cab for operating the trailer tail lift? I run my 600w one off mine. Bought an anderson connection off ebay for 6 quid. Simple bit of soldering using cables off an old set of jump leads. As the cab (MAN XXL) is my full time drive I drilled a hole in the bottom of the left hand outside locker and fed the cabling up under my bunk. I have fitted a pull apart sausage connection behind the cab so it will just come apart if someone tilts the cab without checking.
I got a 300W which runs the Laptop various chargers etc and I run it off the ciggie socket on the Merc as there aren’t any Hella Plugs…never had a problem,I’ve got a 20amp fuse on the inverter cable too.,I leave it running all night as well sometimes and (touch wood)have never had a flat battery.
The only problem Ive ever had with Plugs melting and run down batteries is when I had my 12V Cool box in my MAN,never had a problem in my Scanny or Merc with anything electrical.
I’ve just put that down to MANs being ■■■■.
A 300W will run most things i.e Laptop,TV,DVD etc its only when you want to run microwaves,ovens,toasters etc that you’d need something a lot bigger.
Bilgepump:
we have on the unit but not on the rigids we run (obviously), at the moment i have decided to buy it and then either use the ciggie lighter and get myself down to Aldi and buy a couple of packs of the £1 fuse packs (if they have any left) or even halfrauds or get the ‘L’s’ at workj to knock me an extension cable together for the battery.
i will also have a natter with the boss on friday and see what he suggests (or if i can plant the seed that it would be a good idea to get all the wagons fitted with them)
thanks for all the advice people.
much appreciated
I kept my first post specific to the question.
But I agree with the others that for running a laptop and a few chargers the cigarette socket should be sufficient, and a 300W inverter rather than a 600W. Most laptops draw about 75watts, phone charger is only 2-3watts so you should easily be able to run it off a 300W. To keep safe just check the amp fuse on your cigarette socket, check the voltage/current draw of all your items connected to the inverter and make sure they don’t exceed it, all devices are labelled with their power draw.
Voltage x current (in amps) = power (in watts)
so a 5v phone charger running at 450milliamps is only drawing about 2.5watts.
A 24v socket in the truck with a 10amp fuse in it can supply 240watts, thought as inverters aren’t immensely efficient you’d probably blow fuses when you start loading it with devices drawing about 220watts.
Kiowan,
i have just had a word with the lads at work and they will make me a cable up (all soldered and sealed so no shorting out) but will also put a little bit of armoured surround on it (for where it goes through the sunroof/window). all its going to cost me is a bag of tea bags and some biscuits.
i will try it off the ciggie lighter and see where we go from there. if it works at least i will have a cable for when the ciggie lighter melts or just blows everytime!
i have just had a thought, planted by bilge pump, i wonder if they could put an anderson connection (both male and female to connect the cable when the anderson connection is not needed) in the cable so if i am in the artic i can just plug it in and away i go until i need the tail lift, and on the rigid stick it on the battery! I can get all teh parts for a total of about £15 so might go shopping later!
cheers for all the pointers it has certainly broadened my knowledge of what is needed and how to rig it
