delboytwo:
in the reg it says the above
if you work for a company and your shift stars at 6.00 and you work till 14.00
in 6hours you must take a brake of 30 cos if you read it between 6 and 9 hours
this is what i am getting at when you have work 6 hours you take a brake at 12.00 till 12.15 your shift finish at 13.00 before 13.00 you sill have to take 15 mins brake as you have worked over six hours
Correct, you would have working time of more than 6 but less than 9 hours so would need breaks totalling 30 minutes
delboytwo:
so as you have work 6 hours you must take a brake of 30 before 15.00 as you that is why you have to show that you had a brake at 14.45 till 15.00 it does not matter that you had the 15 mins at 12.00 till 12.15 you only had 15 min you still have to take 15 nins before the 15.00 as you have gone in to the six hour
No, not if you will be working time will be more than 9 hours, you can take the remaining 30 minutes, in one or two parts before the end of your shift, it doesn’t have to be before exceeding 9 hours.
delboytwo:
also to add if you go over 9 hours you have to take 15 mins more
Correct, more than you have to take for working time of 9 hours or less
delboytwo:
so if you start at 6.00 and you shift finishes at 16.00 you have to take 45 nins in total
Only if in the 10 hours duty time, 06:00 - 16:00, you accumulate more than 9 hours work.
delboytwo:
you could do this 12.00 till 12.15 next 14.45 till 15.00 and next 15.00 till 15.15 than work for 45 min and you have met the working time
You would have but you don’t have to take the second 15 minutes at 14:45, it could be later than that.
delboytwo:
if you work 6 hours and 1 min you must take 30min brake before 9 hours are up
No you don’t. Nowhere in the regulations does it state you must take 30 minutes before accumulating 9 hours work. The only stipulation in the WTD regarding taking a break before exceeding a certain amount of work is 6 hours. The remaining breaks, how much you need to take and when are dependent on amount of work done.
As I pointed out above you are reading the requirement for a shift containing between 6 and 9 hours work and applying it to a shift containing more than 9 hours work. The 6 - 9 hour requirement, Section 7 (2) of the regulations doesn’t apply to a shift with more than 9 hours work, that is covered by Section 7 (3).
You also should remember that it isn’t the time you start work that governs when a break must be taken, it is when you clock up 6 hours work, you could start work at 06:00 and not have to take a break until well after 12:00, and in some cases not be required to take a break at all. I do sometimes a shift where I start at 12:30 and finish at 19:30 -19:45, during which I usually do between 4 and 4.5 hours driving and about 45 minutes of other work. My duty time for the shift is 7 - 7.25 hours but as I don’t reach 4.5 hours driving or 6 hours work I don’t require a break for either set of regulations.
