One thing I’ve just noticed is if it’s loaded back to front on a semi lowloader, these things have what’s called a swan neck where the front of the trailer is higher than the back. Measuring the height from ground level to rear rotor would be good to ensure it doesn’t touch the deck first.
Looking at it it could be close so some railway sleepers to sit it on would solve this.
This would increase the travelling height as well though so worth considering.
Also as its 8foot wide that’s the same as the trailer width so it might use the extendable side bars to get a good footing on the trailer. Should still be below the 9’ 6" width limit before the load becomes classed as abnormal.
Course this depends on the trailer chosen but the firm might send a rep or driver out to reccy the job first anyway.
This helps avoid Mr Cockup showing up on the day which is not what you want with a delicate chopper.
For this move a nooteboom semi low loader like I used to have or similar could be used, not my old truck but similar trailer to this.
Notice the swan neck bit I mentioned earlier at the front.
Also due to the delicate nature of the chopper and vibration in transit it might be worth considering if support is needed for the rear rotor.
OMG I’ve over thought this.
