Dear Tech Support:
Last year I upgraded from Girlfriend 7.0 to Wife 1.0. I soon noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. No mention of this was included with the product information. In addition, Wife 1.0 installed itself into all other programs and now launches during system initialization, where it monitors all other system activity.
Applications such as Poker Night 10.3, Football 5.0, Fishing 7.5, and Motorcycling 5.0 no longer run, crashing the system whenever selected. I can’t seem to keep Wife 1.0 in the background while attempting to run my favorite applications. I’m thinking about going back to Girlfriend 7.0, but the uninstall doesn’t work on Wife 1.0. Please help!!!
THE REPLY:
Dear Troubled User:
This is due to a very common problem that generates many complaints.
Many people upgrade from Girlfriend 7.0 to Wife 1.0 thinking that it is merely a “Utilities and Entertainment program” when infact Wife 1.0 is an OPERATING SYSTEM and is designed by its creator to run EVERYTHING! It is also impossible to uninstall, delete, or purge the program files from the system once installed or revert back to Girlfriend 7.0 as wife 1.0 is designed NOT to allow this.
Some have tried Girlfriend 8.0 or Wife 2.0 but end up with more problems than in the original system. Look in your Wife 1.0 manual under “Warnings - Alimony/Child Support.” I recommend that you keep Wife 1.0 and work on improving the situation.
I suggest installing the background application C:\YES DEAR to alleviate software augmentation. Having installed Wife 1.0 myself, I also suggest that you read the entire section regarding “General Partnership Faults (GPFs).” You must assume all responsibility for any faults and problems that occur, regardless of their cause. You will also find that GPF’s are cyclical. The best course of action is to enter the command C:\APOLOGIZE.
Avoid excessive use of C:\YES DEAR because ultimately you will have to give the APOLOGIZE command before the system will return too normal anyway.
Wife 1.0 is a great program, but it tends to be very high maintenance. Wife 1.0 comes with several support programs, such as Clean and Sweep 3.0, Cook It 1.5 (which replaces Burn It 1.0), Trash 4.0, and Do Bills 4.2.
You must, however be very careful how you use these programs. Improper use will cause the system to launch the program NagNag 9.5. Once this happens, the only way to improve the performance of Wife 1.0 is to purchase additional software. I recommend Flowers 2.1 and Diamonds 5.0 should this happen.
WARNING!!!
DO NOT, under any circumstances install Secretary with Short Skirt 3.3. This application is not supported by Wife 1.0 and will cause irreversible damage to the operating system please check your manual under “Warnings - Alimony/Child Support.
Good Luck
