delboytwo:
well here my other spanner in the works explain this then
Last one then because I am not debating this over several pages with you.
delboytwo:
in the 561/2006 regs there this(e) ‘other work’ means all activities which are defined as
working time in Article 3(a) of Directive 2002/15/EC
except ‘driving’, including any work for the same or
another employer, within or outside of the transport
sector;
And sitting in a traffic jam doing nothing work related doesn’t fit with that so not other work.
delboytwo:
Article 3
Definitions
For the purposes of this Directive:
(a) “working time” shall mean:
- in the case of mobile workers: the time from the beginning to the end of work, during which the mobile worker is at his workstation, at the disposal of the employer and exercising his functions or activities, that is to say:
- the time devoted to all road transport activities. These activities are, in particular, the following:
(i) driving;
(ii) loading and unloading;
(iii) assisting passengers boarding and disembarking from the vehicle;
(iv) cleaning and technical maintenance;
(v) all other work intended to ensure the safety of the vehicle, its cargo and passengers or to fulfil the legal or regulatory obligations directly linked to the specific transport operation under way, including monitoring of loading and unloading, administrative formalities with police, customs, immigration officers etc.,
Well you aren’t doing any of that while sitting doing nothing waiting for a jam to clear so still not other work.
delboytwo:
- the times during which he cannot dispose freely of his time and is required to be at his workstation, ready to take up normal work, with certain tasks associated with being on duty in particular during periods awaiting loading or unloading where their foreseeable duration is not known in advance, that is to say either before departure or just before the actual start of the period in question, or under the general conditions negotiated between the social partners and/or under the terms of the legislation of the Member States;
You don’t have to stay at your workstation, you could sit on the bunk or in the passenger seat if you wish so that doesn’t apply.
delboytwo:
so its other work as it says your at your workstation and not freely of his time, see bit in read the driver is waiting for the traffic to move and does not know when
Exactly, so it cannot be POA as the duration isn’t known.
delboytwo:
so I say you can not put it on break while sitting it a traffic jam or what ever as happened to warrant a stop of such a time, were a break could be done it would and only could be count as other work
Sorry Del but you are wrong, what other work are you doing if you are just sitting there doing nothing? It has been explained why but you are doing a ROG and ignoring it. You aren’t going to be convinced otherwise because you are not understanding the criteria for a break.
delboytwo:
i stand by this and would never put on break while in traffic as for me i know that i not on break
That’s up to you, you are wrong but if your lack of knowledge prevents you taking the opportunity for a break when it could mean getting home a bit earlier and benefit you that is your choice. It could even avoid an infringement by preventing you going over the 4.5 hours.
delboytwo:
and to put a point if the truck is not moving you not recording driving it goes to other work cos that’s what it is
I knew you were going to come up with that one at some point but while some tacho units do indeed default to other work some default to break so how does that fit with that argument? Kinda blows it out the water does it not.
delboytwo:
look at it this way if its possible to take breaks while sitting in jams why is in not in the regs as say something like in article 12 if the unforeseen circumstances as a period of more then 15 minutes it my be possible to fit a break in a break my be takenbut as you know it does not give you that option
The regulations do not need to list every possible scenario in which you can take a break. The criteria for a break is clearly defined and it is up to the driver to see if those criteria fit their situation when they want to take a break.
Let’s try it with this situation.
Definition of a break.
Article 4 (d) ‘break’ means any period during which a driver may not
carry out any driving or any other work and which is
used exclusively for recuperation;
Step by step now to see if it fits into being stationary for a period in a traffic jam.
‘break’ means any period during which a driver may not carry out any driving
You aren’t driving, the tacho isn’t recording driving and for the regulations driving is only that time recorded by the tacho unit and you could even have the engine off if you wished so that part of the definition is met.
or any other work
You are not doing any work related tasks so that part is also met.
and which is used exclusively for recuperation;
Maybe the seat is reclined a bit and you are watching the world go by or reading a book or the paper. Maybe having a coffee from your flask or checking out that brunette in the BMW. Thinking about that game you watched last night and how your team was robbed or you might even be resting your eyelids a little. Well all that would count as recuperation so that part of the definition is also met.
Three things required by the regulations for a period to qualify as break and all three met. If it looks like a break, sounds like a break and walks like a break guess what, it’s a break.
And finally Del, how many of these type of discussions have you and I had over the last couple or so years that ran to several pages? Would you agree dozens? Now, how many of them has it turned out you were right and I wasn’t? That would be a big fat zero so what makes you think this time will be different?
And it’s not just me saying this, Tachograph has also said it and other people, including more qualified people have said it in previous threads on this subject.
That’s it, I’m finished with this thread so enjoy the other pages and I’ll catch you on the next topic…
