Jasesonix:
I’m actually pleasantly surprised. I thought most of you would be on microwave ready meals or steak n chips from local truck stop lol. Guess that’s a misconception nowadays.
Just don’t tell the daymen on here.
It’s a well kept secret that tramping aint too bad after all …if you do it properly that is. :
Don’t get me wrong I’ll have fast food or a fry up on occasion. Occasion being the key word. I also cook my own food in the cab, take pre-made food from home and have some handy kettle meals (porridge, mug shot/pot noodle) and the built in fridge is always full of fruit.
I don’t do full on tramping - some weeks I’m out all week, others I’m home every night but I could start my day with a run to Liverpool and end up in Belgium as things change hence why I’m prepared.
blue estate:
Also don’t forget to get a good 10ltr water carrier , not the collapsible ones ,
This is mine
Will defo get one of these. I’ve got a twin camping stove already.
Btw, Do most sleeper cabs have proper power sockets? IE for a kettle etc.
Do you mean proper as in a three pin plug you’ll get at home? In which case no, not unless you’ve got an inverter fitted (search inverter for millions of threads About them)
You’ll normally have a couple.of 12v ‘■■■ lighter’ sockets and a couple.of 24v hella sockets.
Personally for a kettle I use a gas stove and camping kettle.
[/quote]
[/quote]
I see ok. Does a microwave operate in a Hella socket via an inverter than or the 12v socket?
Jasesonix:
[/quote]
[/quote]
No you need an inverted for microwave
Jasesonix:
[/quote]
[/quote]
No the inverter is wired into the vehicle via a number of ways which I won’t bore you with, you can then plug normal plugs into it.
Just if messing about with inverters always cover your backside by asking the boss and getting a workshop to do it. It can be wired up yourself if you know what you’re doing but if you don’t and you turn a V8 into a BBQ due to fried electrics I’d imagine it would be a fair old cloud hanging on the horizon for your future job prospects within the company
To echo what others have said; if you’re fitting an inverter and unless you know your way around electrics then definitely see your garage to have it fitted. This one cost me a crate of supermarket lager to be done, heavy duty cables run from the fuse box under the floor and neat and tidy.
the maoster:
Mine is wired from Anderson socket for tail lift via a plug and thick cables
I’ve got mine wired in via the Anderson lead. Back when I had an MAN I had mine wired in behind the fuse box. There is a connector that connects directly to the battery. Just had a mini-Anderson lead with a mega fuse knocked up for it.
I have cereal in the morning, a pasta salad around midday, 2 bananas and once parked up i have a Naked Noodle which are much tastier than Pot noodles.
Thought i would treat myself last thursday in St Ives and went to Wetherspoons for Curry night. It was on my table seconds after i had ordered it and it was lukewarm and the fosters was flat. Should have stayed in cab and had a Naked Noodle.
Usually take a cpl of home cooked chili con carne, beef veg mash, enchilladas, sweet and sour chicken. Kept in fridge and cooked in microwave…wouldnt be without it and my inverter nowadays…
gray_nw:
