Hi tachograph
tachograph:
No Del you’re not right about that.
After six 24 hour periods you must start either a weekly rest or a reduced weekly rest, sorry but I’m a bit confused by your example but however it works there will need to be at least a 24 hour rest period after six 24 hour periods so you can’t possibly work 2 weeks with just 2 minutes rest falling within the two consecutive weeks
if you look at my example you will see i put the 24 hours in
delboytwo:
week 1 00.01 start work on sun takes 24 hours for 144 rule finishes work sun 23.59total rest 90 hour but actual rest 2 mins in two consecutive weeks the 24 hours rest is not counted
as the 24 hours in the two week can not be used as you have already counted the 1 min as a 45 hour rest for that week the 24 hour as been put there for the 6x24 hour rule then when you finish at 23.59 that 1min count as rest for that week 45,but if you look at that all the actual rest in those two weeks was 2 mins cos you can’t count the 24 hours in either of those week as you have already count the rest for those weeks
tachograph:
You left this important bit out of your quotes
- A weekly rest period that falls in two weeks may be
counted in either week, but not in both.
have a look at that bit then consider this
if you have to have at least a 45 and 45 or a 45 and a 24 in the two consecutive weeks
delboytwo:
In any two consecutive weeks a driver shall take at leasttwo regular weekly rest periods, or
one regular weekly rest period and one reduced weekly
rest period of at least 24 hours. However, the reduction
shall be compensated by an equivalent period of rest
taken en bloc before the end of the third week following
the week in question.
this is telling me that in two consecutive week you must have at least 69 hours of rest or at least 90 hours rest
i will try and get across what my thinking is, sorry the way i put it but i am not the best writer
lest say you work a week and that week is and always going to be
Monday 6.00am till Saturday 9.00am when that drive does this he always get a 45 regular rest in
if you look at that you will see that in two consecutive weeks the driver will have 90 of rest in those week
but lets look at it that one week the boss asks him to do an extra 2 hours this Saturday till 11 am
those two consecutive week he as only had 88 hours of actual rest
now look at my first example
delboytwo:
week 1 00.01 start work on sun takes 24 hours for 144 rule finishes work sun 23.59in these two week the amount of actual rest was only 24 hours and 2 mins
i know to have counted that as a full rest not disputing that but, if the regs say that IN two consecutive week does that not mean IN two weeks you must have at least 2x 45 or at least 1x 45 and 1x 24 which
cos if you think of it if you have any compensation that you owe from week 1 you have to pay that back by the end of the 3rd week following the week in question that would be 24.00 sun
so when the driver come back to work from paying the compensating rest back and the week starts at 6.00am and finishes an Saturday 9.00am then takes 45 off, starts again at 6 am Monday and the finishes on Saturday at 9.00am takes 45 of would mean that he only had 84 hours of rest, unless you can count the six hour at the start of the week other wise you will always be paying compensation back and if you look at that you would see that IN two consecutive week you have had A 84 hours actual rest or B as I see it 90 hours actual rest
i am not disputing the fact that you can use a rest in either week but you still must have 90 hours of rest in those two consecutive weeks unless you have take a reduction to a minimum of 69 hour rest
