dave150267:
so basically i need 45 every weekend then? if i do have a 24 one weekend the followin weekend has to be a 45?
Yes, and the number of hours less than 45 you have, 21 in the case of a 24 hour rest, will need to be compensated for. They have to be added, in one block, to another rest of at least 9 hours before the end of the third week following the reduction. So, if you count the week in which you take the reduced rest as week 1 you will have to add the hours to another rest period before the end of week 4.
so at the end of week 4 id need to have 45+the 21 reduced which is oweing?
does the reduced hours (21) have to be added in one go an does it need to be added to a weekend rest of 45 or can you add hours here an there?
or can the 21 be added to a daily rest of 11 hours to make a 32 hour rest?
dave150267:
It would have to be at the latest before the end of week 4, you could take it earlier than that.
dave150267:
Yes, that’s why I said ‘in one block’ in the last post.
dave150267:
You can’t add it here and there, one block remember, and it can be added to any other rest of at least 9 hours, daily or weekly rest in other words.
dave150267:
That would work, or 9 + 21 to give 30 hours.
Note, you don’t have to add 21 when you take a reduced rest unless you reduce right down to 24 hours. You only need to compensate the actual number of hours less than 45. So, if you took a 40 hour weekly rest you would add 5 hours to another rest period, take 32 hours and you add 13.
If you are not sure if you can do a shift or not stick a post on here with details of your last weekly rest, when it was and what hours you’ve worked since and someone will keep you right. Be a shame to turn work down when you could do it.
true mate thanks for the help
by the way you still doin over the water?
dave150267:
Yes but just local stuff not any great distances any more.
