Rjan:
Rjan:
Cold engines also have looser tolerances, which is why the oil should be relatively thicker at cold than it would be with everything at operating temperature.Just to correct myself, I’ve got this the wrong way around - no engine ever got tighter with heat applied!
But the principle still stands: that multi-viscosity oils are basically specified to be suited to the lubrication requirements of the engine both hot and cold.
Oil that is modestly thicker when cold does not necessarily starve any surfaces of lubrication.
Mass-production engines would not be designed nowadays with surfaces that couldn’t be lubricated for an appreciable number of minutes while the oil heated, because the amount of friction wear would be rampant.
To a point, thicker oil simply increases mechanical resistance (whist still providing adequate lubrication), which if anything generates heat and helps to warm the oil which can only be a desirable effect in this situation.
That is why the manufacturers advice is to give the oil a few seconds to circulate and pressurise, but no more.
It’s clear that the least possible demand on the oil to seperate the moving parts of an engine is when it’s idling not under any load.Also bearing in mind that there is a difference between engine speed ( high idle ) as opposed to ‘load’.The oil cooler and water thermostats are what gets the engine up to temperature while a vehicle that isn’t moving obviously applies less cooling effect to the radiators as they open thereby providing a marginal reduction in the time needed to get the oil and water up to their optimum operating temps.Although having said that modern synthetic oil obviously changes things to a point but viscosity is still more about the fact that it needs to seperate fast moving parts under high load while providing optimum circulation at low temps.Bearing in mind that engine tolerances definitely close up at working temperature while synthetic oils can go up to 60 grade when hot.Which proves that they are designed to provide maximum protection at working temperature.IE putting an engine under any type of considerable load at low temperatures means that the oil will be at its weakest ( as low as 5-15 grade ) because at those temperatures it’s designed for circulation not protection.
As for supercharged piston aircraft.By FD’s logic they’d have just fired her up taxied out and took off ?.In which case I’d prefer nmm to be the pilot if we’re going out on a raid over Germany.While we’ll put you on the list as tail gunner so you’re as far away from the cockpit as possible.
Er, ok
By my logic?? As in, I just came up with this
? These were low level maritime patrol aircraft for the coastguard as well as turbine types. Not some Sunday jaunt in an Austin allegro. It was standard operating procedures. I think the fleets written procedures on how to operate our particular turbine and super charged aircraft were a little more robust than your opinion. I did not say we “fired them up” and took off. I said we limited operating the supercharged piston engines at excess idle.
