]For the umpteenth time you can’t ‘improve’ the ■■■■■■■■■■ of a cold diesel engine.It’s the same whether it’s idling or under load.
Mmm, puzzling response
So its known a diesel will operate at higher temperatures with increasing engine speeds or loads. And its proven that combustion is improved in both cases.
So you’re suggesting increasing the engine speed of a cold engine or driving away will nett the same slobbered combustion, the same combustion chamber temperatures, or the same mechanics of atomisation and mixture rate.
Intriguing. So all the papers and studies by various manufacturers, defence companies are wrong.
Just out of interest. Why do you think some manufacturers build in a reving sequence into their start programs? Why do some manuals urge to drive away after start? Don’t tell me, it’s solely for the greeenies
. Perhaps it’s the engine builders want you to just chuck in more fuel willy nilly? After all, you tell us all this does is “wash the bores” ![]()
So despite, evidence to the contrary, you think there is no risk with idling a diesel and in fact, increased revs or load only exacerbate the risks of wet stacking, glazing and bore score. Ok ![]()
