Freight Dog:
newmercman:
Just skimmed over the last few posts, didn’t really take any of it in, I’ve just done a 700mile overnight shift, so I CBA, but the gist of it is that I agree with our resident lunatic, but from his posts we agree for different reasons, I like my engine up to temperature before setting off purely to thin the oil out so it can do it’s job better, all the rest of the apparent reasons are of little interest to me.My engines sound smoother with a bit of heat and my completely free flowing exhausts on my CAT engined lorry blow out no visible smoke under load, save for a puff of black smoke when I change gear, that’s old school seat of the pants stuff and it makes me happy.
Sent from my SM-G930W8 using Tapatalk
The resident lunatic’s theory is a confusing hotchpotch of questionable deduction and misuse of terms such as piston slap that does not dovetail with accepted theory. Despite inward conflict and questionable arguments he is now a proponent of something that we all have been stating since the beginning by what appears, happy accident. Instead of defending idling a diesel to warm as per the original post, he has subtlety migtrated to the subjective term “high idle”.
What that means is running an engine at higher revs than idling, which we’ve all since post one stated the research shows is beneficial over idling and indeed appears in many manuals. In essance this is to take the engine out of the risk area associated with idling. Running under light load is an optimum method that does appear appear in some manuals. In light of the findings, it appears manufacturers are increasingly building in automatic engine start sequences that progress the engine schedule away from idle where the risk of glazing, bore scoring and wet stacking are most prominent.
A flick through my prior posts will spot a consitant personal approach. I have time and again advocated following manufacturer guidance above all else. Not least because manufacturers change the software and hardware in response to development and research. Which is why I find the staunch across the board advocates of “idle to warm” so hard to comprehend. Such an attitude shuts out reception to feedback. It is perhaps recognising that old habits die hard that has lead to manufacturers fitting automated engine regimes such as turbo timers and engine start sequencing to protect users from this stubborn trait.
It’s absolutely clear that I was referring to ‘high idle’ from my first post on the topic.
While it’s equally clear that you were/are referring to warming it up under ‘load’ by driving it off with a cold engine.In which case I’m still waiting for an answer to that question as to why the example in the video shows the least smoke ( unburnt fuel ) and therefore fuel wash at idle and the most under load ?.
IE this argument is all about warming up an engine using ‘idle’ as opposed to ‘load’.With both you and Rjan clearly being on the side of using ‘load’.Until I showed the real world results of such silliness just by looking at an open exhaust stack of a cold engine showing the results of what happens when you put diesel into a cold engine with idle being the least problematic and load being the most.
With you then seeming to be confusing engine speed with load when the two things are totally different and which is why I asked you if you could read a fuel map.Obviously not.Having also obviouly confused the fact that it’s the cylinder temperatures which totally wrecks the combustion process in a cold engine not the engine speed or the load factor of the engine.Chucking more fuel into a cold engine in the form of load just adding to the problems caused by the poor combustion not solving them.As shown in the video. ![]()
