hoty2008:
Just something to bear in mind guys when using self employed drivers, is the tax man.
We had a tax investigation last year, we had used one self employed driver who had also done some building work for us. It was a very lenghty process and took up a lot of time. I think if he hadn’t done the other work they would have tried claiming the tax and paye.
Poblem is the tax man is a complete arse and has never worked in industry GB.
Fortunatly we run 20 trucks now and have spare drivers to cover holidays/sickness. We will not use anybody self employed, they are all treated as PAYE.
BEWARE!!!
Not true, Im S/E and Im busy, BUT, I`ve got the correct paperwork to back up my “TAX” position.
If you don`t request the correct info, then your going to fall prey to the cowboys, which are getting fewer by the day. The tax man has a job to do, and is a jobsworth if he smells a rat.
Your builder geezer / driver is a genuine S/E person, there are loads of us about, the tax man would go after us first, its when they cannot find “John Wayne”, that they come back to you.
Makesure that their business card + invoice has their HOME address on it, and check it against the electoral register.
They obviously found something in your “payroll” department that did`nt add up, you only need to give a stuttering answer or just come across as “notsure” and they set their teeth into you.
Been there / done that, in a previous job, got stitched up because of one persons clever comment.
