Hi all, after a bit of advice, anybody here work for or know how much Wyvern Cargo pay, they ask for Wage/Salary required and i dont have a clue what to put?
cheers shorts
cheers shorts
How much would you like?
start at £20 per hour and negotiate
war1974:
And settle at £7.80…
well the way i see it is if you go to high your cv will just go straight in the bin but to low and and you could be missing out, as for what i would like well £20 ph would be great but i would expect £10 ph would be more realistic
Put £10 per hour, if they don’t accept it, they`re not worth working for just add more than what your on now ! it does annoy me when companies have a wage structure that’s different with each driver, depending on what they will put on the application form, or leave that part blank.
truckyboy:
Put £10 per hour, if they don’t accept it, they`re not worth working forjust add more than what your on now ! it does annoy me when companies have a wage structure that’s different with each driver, depending on what they will put on the application form, or leave that part blank.
Lets up the ante £12.75
Add 15% to your current salary/wage and ask for that.
Never mind hourly rate
£10 ph x 40= 400
£10xph x 80 = 800
Lot of difference ,you first need too know what you need too live on ,it’s no good putting down £10 p.h and ending up doing doing 40 hrs p.w = £400 if you need £500 to live
How much to live on- minium hours I’ll get p.w- then put down what you want/ need p.h .
put down neg and see what they offer.
shorts:
Hi all, after a bit of advice, anybody here work for or know how much Wyvern Cargo pay, they ask for Wage/Salary required and i dont have a clue what to put?cheers shorts
Just put £00,000 i see this on a lot of cv’s in our place and it never stops them getting an interview.
Write, “Willing to negotiate”
Always worked for me.
great thanks for all the advice, one other thing (never been great at doing job applications) they obviously want my job history but if i included a CV could i just write see CV or should i write it all out and not bother including a CV?
thanks all
I presume you are filling out the application form, from thier website. There are spaces on it for current and previous work history,
so no I wouldn’t attach CV.
