To avoid it again recomend to ur mate to back hand a handy volvo technician to switch off his adblue system then he’ll have no more problems the 5o is non the wiser his monthly fuel bill will be less & it will still sail through a mot on emissions
cats are easily cleaned out with detergent and water.the little holes in the baffles get blocked and causes lack of power.
shirtbox2003:
Hi Shirtbox,
Could you please explain how it can be done \
Is some kind of back wash with water mixed with some special detergente or we is a need to open the cat \
Edzio
the cat has to be removed to clean it out properly… i only ever clean cats out with a high pressure air blow gun as i have seen in the past the “dusty” carbon build up just turn gooey & completly ruin the cat when liquid has been used.
truckers boy:
never had owt to do with cleaning out a cat, out of interest how much crap do you blow out after taking the thing apart?
it’s just that I have a vision of a fitter stood outside the garage door blowing the crap to where it would have been if the thing was not fitted in the first place!
Moose:
truckers boy:
the cat has to be removed to clean it out properly… i only ever clean cats out with a high pressure air blow gun as i have seen in the past the “dusty” carbon build up just turn gooey & completly ruin the cat when liquid has been used.never had owt to do with cleaning out a cat, out of interest how much crap do you blow out after taking the thing apart?
it’s just that I have a vision of a fitter stood outside the garage door blowing the crap to where it would have been if the thing was not fitted in the first place!![]()
there is ■■■■ loads of sut comes out its a good idea to wear a mask
& yep that is excatly what happens outside & blow it to atmospher ![]()
Maybe get the scrap cat repaired and save as a spare or sell it.
if a man made them another can zb it or fix it.lol.
Should have took the cat off bashed the hell out of it with a big stick,First removing NOx 1 and NOx 2 sensors refitted it and saved himself a whole lot of cash.
its all tripe no way can an inboard ecu measure NOx levels down to 6 parts in a million.They do not even have this at test stations they go on ecu readouts which are also a load of tripe.
Bking just ■■■■ off , you no nowt
I bet you are friends really ![]()
truckers boy:
Hows the jet engines going sweet thing ■■■
