Hi everyone,
Does anybody know what the possible causes are for the following:
Mid 136 sid 1 fmi 10
And
Mid136 sid 2 fmi 10
Thanks in advance charlie
Hi everyone,
And
Mid136 sid 2 fmi 10
Google says…
Mid 136 Sid 1 Fmi 10 is a abs fault for the left front abs sensor has a intermediate signal loss. I would inspect the sensor and the wiring and plug.I would also jack front of truck up and make sure wheel bearings are tight. I would try and adjust sensor by lightly tapping on it to push it all the way in and driving it and seeing if that helped. If not i would try and replace the sensor. If you have anymore questions, just ask.
Don’t know about the second one, but possibly the sensor on the other side?
Harry Monk:
That’s correct…
MID 136 SID 1 ABS Wheel Speed Sensor, Steer Axle (L) 1
MID 136 SID 2 ABS Wheel Speed Sensor, Steer Axle (R) 1
FMI: Abnormal change rate = 10
okay thanks for your help
With them both throwing a fault I would be looking fuses/wiring/ecu side of thing. Sensors could still both be faulty or out of range but I would eliminate elsewhere first.
