Using the forum correctly...Help
I notice there are nearly 38000 topics… How do I look at just todays posts or this weeks posts :unamused: :unamused: Thank s in advance Phil…
Click on - Board Index at the top left, then - View New posts :wink:
DAFMAD:
Cheers I knew it couldn t be that hard…
If you create a short-cut on your desktop and for the location use http://www.trucknetuk.com/phpBB/search.php?search_id=newposts it will take you straight to the new posts when you double click the short-cut.
tachograph:
Thank you
The above posts assume that you already read the 38,000 threads and only want to see new ones - you have read them all haven’t you :wink: :question:
Here’s another tip, if you go to “board index” (top left), click that, then when that page loads look in he top right for a “mark forums read”. If you click that it will clear the forums as though you’ve read every single post/topic. Gives you a chance to keep up with the new posts then.
