…in the same shift. On some days, I can start in a truck with a type 1 digi’ (8w), do all the 8w orders then change to our 6w with analogue. I write on the chart “on digi (insert times)” then do all the work for that vehicle. I then drive our new puddle jumper with a type 2 tacho. I write on the analogue chart the times I used the type 2. If I then do yard work on the diggers I record the other work on whatever was the last vehicle used.
Is this all ok with DVSA or is there something I’m missing? Apart from inserting broom into ■■■■ and sweeping up that is.
