Using 24v Waeco Kettle in Scania
Tried searching but not found an exact answer.
It’s occurred to me I am spending a bomb on takeout coffees, not being able to do without a brew I am considering investing in a cab kettle to carry. The Waeco ones seem the most well regarded. Am looking at the 24v volt one but a few reviews in the comments on Amazon say you need to be careful the socket in the truck can handle the wattage.
The kettle pulls 380watts. If I bought the kettle & a hella adapter and plugged it into the 24v socket facing the passenger seat in a Scania, would it work or blow up?
A gas stove isn’t an option by way of some company policy.
If you want to use a 24 v kettle get your workshop guys to check out the amperage to your 24v outlet, I once plugged a 24v kettle into the 24v socket on a Scania and burned a lot of wiring out, luckily the workshop covered for me, fixed the loom and fitted a separate socket wired directly to the battery.
My present truck is US made and as a result only has 12v sockets but even though it has 7 of them scattered around the cab, they are all different amps, my fridge kept blowing fuses until I located which socket had the highest amp setting.
Dont bother with adapter will not work you will need a 30 amp hella plug
just cut the plug it comes with off and re wire the new plug and away you
go i had to do that,its the recommended way to go i got mine from cdc truck
shop.
Get a gas stove and kettle far quicker and a lot less hassle
Got one myself and as stated check your sockets for the amps/watts capacity. Unfortunately I ain’t got a Hella socket (CBA to fit one) but get away with an uprated ciggy adapter and change the spring every few weeks.
I also carry a huge flask that I fill up regular and use the kettle just to whiz the hot water up to temp.
Works well for me and boils 2-3 cups worth in about 10mins. Running the engine helps but not for long or I burn out me tip.
Also got a gas stove for when no one’s watching.
Mazzer2:
This. Those 12 or 24v kettles are a waste of space, even the Waeco ones. You can buy the flat cooker in a case for a tenner or less and a couple of quid on a kettle and you’ll have a hot drink in a fraction of the time it takes an electric kettle to warm up
Actually do you drink tea or coffee? If coffee the Waeco filter coffee machine is a nifty gadget. Used to have one myself and used it so much until I gave up tea and coffee and caffinated drinks
Mazzer2:
switchlogic:
rob22888:
When I was tramping I had a small two cup 24v kettle as well as the gas stove and hob kettle, I used to put the 24v one on about 10 mins before getting to where I was stopping even if that was just a quick pit stop in a lay-by to make the brew and then be off again, never had a problem with it tbh, it wasn’t a waeco one though it was just a cheap truckstop jobbo can’t remember the make roadking or something maybe?
Reef:
Mazzer2:
switchlogic:
rob22888:
Unless pulling hazardous I would still use a gas cooker company policy or not you don’t have to tell anyone!!
Mazzer2:
Reef:
Mazzer2:
switchlogic:
rob22888:
What they don’t know won’t hurt them. When you’re down the road who’s to know anyway
Thanks for the replies, feeling although the electric kettle idea is too much of a faff to be honest. I work days & just wanted to keep it in the car and easily throw the thing in the cab & plug it in if I was on for a long day.
Looks like I’m gonna have to dig out the Stanley flask, the brew just never quite tastes right though :cry:
