Trying to start my 2006 volvo fm with I shift but its displaying a message saying “check gear selector at next stop” then when I cancel that message it says “engine starter, gearbox not in neutral”. When I turn the key all I hear is the relay clicking. Gear stick is definitely in N!
Sometimes if it has knocked into gear whilst off and you loose air over night it will lock in gear and of course won’t start to build up air, unless you have a way of filling the air tanks, or could just be a simple connection
mucker85:
I had the same problem with a coach. The relay for the I shift was dead so we just swapped it with another one to get us going.
Did the above, I think it was swap 5 with 7, you lose the intermittent wipers but it gets you going.
100% correct guys!
I fiddled about with the relays and managed to stumble upon the solution that Fileep suggested. Swapped relays 5 & 7 and as if by magic a big ‘N’ appeared on the screen meaning I could then start her lost my intermittent wipers for the time being but in the middle of a heatwave I’m sure ill cope!
Thanks everyone for your suggestions, must remember them in case anything silly happens in the future
