Star down under.:
10 gallons v 45.5 litres,
1 pint v 0.56 litres.
1 thousandth of an inch v 0.0254 mm,
1 mile v 1.6 kms,
A bridge sign showing 14 feet v 4.26 metres.
Do you want the pilot of the plane to measure where his wheels are above the ground on landing to the foot or to the metre.
Which makes most sense.
Centimeter will suffice.
25 hundred, 1 thousand, 5 hundred, 4 hundred, 3 hundred, 1 hundred, fifty, forty, thirty, twenty, ten, so do you want all those figures to mean metres or centimetres, or yards, or inches your choice but if you get it wrong you’ll tear the gear off then crash and burn when it hits the ground.
youtube.com/watch?v=F7D33_u9DE0
Star down under.:
1 mile v 1.6 kms,
I would prefer to have the pilot sat in the left hand seat, rather than be outside with a yard stick measuring his altitude.
Bridge heights?
4.0metres vs 4yds, 1ft, 1.48031inches. ? Yeah, right.
Ed to add
Story from John Allen Paulos, he asked students to calculate the speed of growth of a beard. One of the students argued that beards "dont grow in mph". If Carryfasts plane hits the ground too fast it will hurt. Measure it in units of knots, mph, kph, m/s, or mach, yards per annum, light-years per lunar month, or whatever you like. The speed is the same, and too fast is too fast.
Franglais:
Star down under.:
1 mile v 1.6 kms,
Bridge heights?
If Carryfast`s plane hits the ground too fast it will hurt. Measure it in units of knots, mph, kph, m/s, or mach, yards per annum, light-years per lunar month, or whatever you like. The speed is the same, and too fast is too fast.
That’s why we do bridge heights in feet and inches not yards feet and inches.
So 4m is rounded down to 13ft at most 13’ 1’’ if the bridge is 13’6’’ that’s 4 metres, 1 decimetre, 1 centimetre just like if we were silly enough to measure it in yards, feet and inches.
So by your logic do you want all those height call outs provided to the pilots from the altimetre to mean metres or centimetres instead of feet including the final ten.What’s speed got to do with other than the fact that take off and landing speeds also aren’t measured in metres or km’s per hour.
