Hi, I’m looking at changing my 16 tonner for a new one. I’m thinking of getting a trailer coupling fitted to the new lorry so that I can pull a trailer to increase productivity. Would anyone know What the maximum train weight would be with a 16 ton prime mover and what trailer I’d need eg twin/ tri axle or A frame with front steering axle.
Pogo60:
Thanks in advance
If it’s close coupled going for 40 t 2 + 3 will be a drive axle weight liability similar applies even in the case of 2 + 2.It’s also more involved than just fitting a ‘trailer coupling’ it’ll need plumbing and wiring for the trailer air/electrics supply IE drawbar spec.Better to also go for a lifting tag axle which will provide more tolerance of nose weight and 44t gross capability with a 3 axle trailer in whichever configuration A frame or close coupled.While technically only A frame configuration is train weight,close coupled is combination weight which is what creates the trailer nose weight v drive axle loading issues.A frame 3 + 3 is the way to go as the regs stand and the best all rounder for payload potential without any axle weight issues.
AS Tony says, while it may be legally 40 tonnes for a 2 axle rigid plus three axle trailer you will need to specify that you want a 4x2 rigid capable of running at 40t or whatever with a trailer. An 18tonne rigid vehicle, or the 16 tonne? you mention, will not necessarily be designed to operate at that weight. There are lightweight rigids which can be equipped to tow a lightweight trailer at maybe 24t all up and heavy weight rigids which are really long wheelbase 4x2 tractor units with a body which can tow a trailer at 40t all up. The latter will not have the same payload capacity on the rigid as a lightweight one.
Thanks for your help. Well most of you, not too impressed with the smart ■■■ answers from two of you. The reason I’m asking about a 16t lorry is that the 16t Volvo I run now is 4 inches narrower than an 18 tonner. If I go up to 18t I won’t get into most of my jobs as I work in rural areas so access’s is a problem. The other reason why I joined this forum is that I can find all the info about 18t that I need but 16t information is hard to find and I wanted to make sure that my thinking of maximum train weight was correct. The lorry will obviously be fully fitted with electrics and air couplings from the factory. Thanks for you help.
Is it any cheaper to buy the prime mover if it’s pulling an A frame trailer as opposed to close couple. Was thinking less weight transfer with an A frame so may be less beefing up of chassis or suspension. No idea as never brought on , just nosey.
Looking at the DAF configurator, the heaviest GVW on a 16ton truck is 28ton.
Although all the above posts recognise that a two axle truck, can be coupled to a multi axle trailer, the OP specified, and repeated its actually a 16t truck he runs, and it will be limited in engine size. Thatll likely be the limit in GVW in his case, not axle weights.
Beau Nydel:
Could go 44 ton if he goes Scandinavian style with a 4 axle A frame but I still think ‘troll’.
Our length limits won’t allow for a viable 2 + 4 configuration.IE 2 axle dolly and 2 axle 40 ft semi trailer.But would be an interesting idea.At which point might as well revise the regs Scandinavian style to allow an 8 wheeler pulling a 5 axle trailer making a 20ft and 40 ft container load viable.
Pogo60:
Reduce the 40t max by 2t so 38t GTW with a 3 axle A frame trailer.For many of us an 18t 4 wheeler is a weird modern alien concept anyway.Like needing a class 1 to drive that outfit.
Franglais:
Franglais:
