Depends if it is wired in start at the socket end it will be wired through the fog lamp socket or ‘S’ socket,then follow back to each junction box… i think it’s pin no.3 the yellow wiire IIRC.
mickfly:
Reverse lights are not legally required on a trailer.
true, but its nice to let others know my intentions. I also want a reverse alarm fitted at the rear so its a dual purpose thing.
Wouldn’t expect a standard trl to have the wiring in its loom.
Be careful that the reverse alarm must be cancellable at night time.
Also be aware, & i know no details at all, that the type of “noise” generated could well be covered under future new laws. White directional noise is what you want.
mickfly:
You say that but most of the Sainsbury’s trailers I drive, you can’t silence the trailer reversing alarm…only the alarm on the tractor unit. Considering the majority of stores I deliver to are next to houses, I’m amazed Sainsbury’s haven’t been landed with thousands of court cases.
