wildfire:
blackcats:
Thats the same as mine,thursday night i got E 44 flashing up,what does this mean ,glow plug fault will need replacing
Thanks
wildfire:
blackcats:
Thanks
Quinny:
I would say it was karma.But Iâve had the keys to a 63 plate G440 this week, and the heater control is on a curly lead, but no matter how hard I tried, the temp wouldnât go above 10 degC.
Whatâs that all about.
Ken.
Temperatures just graded 1 to 10, not in degrees, set on 3 does me for overnight.
Timer is a doddle to use, and big easy to read display as well as alarm function.
One of these? Never figured it out yet - over complicated load of tosh to be honest. Unless you know how to use it??
fredthered:
One of these? Never figured it out yet - over complicated load of tosh to be honest. Unless you know how to use it??0
that is a doddle to work and the timer function that you can set for the week is great
cliffton 27:
fredthered:
Care to share clifton27?
As with most things, the user handbook is never in the truck when you get it and the guy that has the key to get itâŠ
Well you get my drift! Any help would be gratefully received! ![]()
fredthered:
cliffton 27:
fredthered:
the top left button is the timer if i remember it flashes up with the day off the week press ok on said day set time then set temp use the pluss and minus buttons to scroll through the options
you can set the heater to come one three times over a day
i hope this is some help i havent used a scania in over a yr and i do miss coming in on monday morning to a nice warm cab in winter
fredthered:
Youâve done something right, the symbol after the time means the timers been set ![]()
Icee:
Drift:
:lol:
It has a mount âbehindâ the drivers seat lol.
I like the truck an oldy but a goldie, though on the grapevine I am hearing about a possible upgrade next year if things go well.But I aint letting this remote heater monster beat me
How stupid can a driver be â â ?
. Press 3-4 seconds for on/off like any webasto controller unit. Temp can be set in 10 steps on the controller. 1-10 going through the pressing the button in the middle. Then use the < ans > to set it, 3 or 4 is usually okay. up again to confirm. Rest is timer. Works like a Webasto timer except it says Scania on it and is not small and black. Most simple thing in the world
Normally if itâs still stuck on full heat itâs the valve behind the front mask under the wiper mounted on the coolant hose thatâs stuck. A knock or 2 on it and it will work like a charm again.
No wonder trucking is taking over by east Europeans with drivers having problems like this
Do you just search the forum looking for people moaning about your beloved Scanias? You do a nice line in being patronising. Let me try this patronising thing, its clearly not that the most simple thing in the world now is it. You took 8 lines to describe how it works. Let me tell you how mine works-
Press heater switch, turn dial to adjust heat.
A bit simpler no?
I remember those controllers, heaps of overcomplicated crap.
Same on my Volvo. Switch it on set temp. done!
skinhead:
fredthered:
Nah! Somebody else did it when I was off thats why I wanted to get it sorted and I have now thanks to â27â!
An on/off temp switch would have done the same but they couldnât charge enough for that! I used to have no problems with the Volvo one ![]()
Icee:
Drift:
:lol:
[/quote]
Thank you for your informative post, that bit was most welcome.
But should you ever have the need to visit the UK and be in the Merseyside area please allow me to thank you personally with a slap.
To paraphrase a quote âstupid is as stupid doesâ and you my friend made a â â â â of yourself.
If you are brave enough for a chat reply to this and I shall reply with my address and phone number.
Git
