To settle an ADR argument
It’s DGSA, you are gonna struggle if can’t get that bit right[emoji3], you’ll be fine loads of study time yet[emoji15]! Get reading Good Luck[emoji106]
Boris1971:
Thanks for reply DD. I know unlikely but if on a CDG journey would u require EAC in top column?, do u not need PSN on each side for CDG journey?, Thanks In advance for ridiculously thorough answer[emoji3].(tank container question).
Hi Boris1971,
A tank container journey under CDG is not as unlikely as you might think. :smiley:
Yes, CDG requires that HINs are to be replaced by EACs as in this example:
The PSN written on two sides would only be required for a UK journey if the journey involves a ferry, so that’s quite possible.
