cav551:
I have found that corrosion prevention by giving the socket a quick spray of WD40 on PMI can result in the rubber gasket behind the pin base plate swelling and making it very difficult or even impossible to push the plug in far enough to fasten the clip. So far I haven’t seen the same thing happening with electrical cleaner.
Also very interesting. Based on earlier comments, if it doesn’t go in far enough to get the clip over (which some don’t) , this could well be enough to prevent a connection.
cav551:
I am very pleased to see this sort of feedback/interaction from a manufacturer directed specifically at us, the end users, particularly as it seems that any criticism is not being brushed off in an aloof manner. We need more of this please, the greater understanding we have of what systems do the safer all of us will be. So much of the time we feel that our experience of actually operating or maintaining a product just never gets back to where it might influence an improvement. Please keep it up.
If one compares the level of technical knowledge required to obtain a heavy vehicle licence in the UK with what is required in the USA then the UK lags behind considerably.
I have already passed (with permission from Peirre) one comment directly to B&Q Compliance.
If we are to remain at the forefront of “innovation”, we should be interacting with end users to develop solutions that work better, operate faster, don’t break and provide the best return on investment. In our view, the drivers are the end users of many assemblies and components on a trailer. The consignors and H&S teams have a different set of interests. We have to react to all party requirements.
We would like to thank everyone who participated in this feedback.
As an update, we can confirm that the ISO 7638 (EBS) affects the following:
- Powers the trailer’s brain and powers air valve solenoids.
- Auto adjusts suspension relative to load weight and braking weight shift. Also returns to ride height if suspension has been fully raised for loading.
- Power the trailer roll stability (RSS). There are 3 phases of severity but all have some degree of auto-braking to protect the driver.
- Adjusts braking power relative bogie weight to prevent locking or insufficient braking force (LSV). Also optimises brake liner life.
- Ensures fast electronic braking response time. Without it, the braking system relies on the slower response time of air passing down the yellow line.
- ABS anti-lock braking (ABS). Without EBS power, the solenoids do not have the ability to oscillate the braking power.
It does not power either marker lights (24N) or GPS/Telematics which are unrelated.
There are other functions as well, as CAN data passes from the tractor down the EBS line (such as the ECU recording tractor time) but these are the critical ones.
Aside from being a legal requirement, the EBS line is a very important power and communications line. Without power, you’re just pulling a dead weight behind you with rudimentary yellow air-line braking only. A lack of EBS can lead to brake locking, jacknifing, bridge strike, longer braking distances and rollover.
More info is available at donbur.co.uk/news/disconnec … -accidents
Thank you again for looking and sharing. It means a lot to us.
