i’ve been doing hiab work for quite a while on agencys
driving rear wheel steers - easy reversing/backing them in … well awkward getting them out …lol
especially when doing hiab work in tight spots/driveways. They do swing out atlot more… just use your mirrors and make sure you allow for that. watch out for fences , low line railings and brick walls when pulling away. eventually you’ll get a feel for it.
i’m currently driving 8 legger tankers with front wheel steer their brilliant getting in/out of sites , but more of a pain reversing around sites,
as for using hiab/brick grab heres a few pointers
always tell the customer were he can have em , dont listen to some of them with their dodgy requests .i.e i did one drop of 40 6 metre long timbers and the knob head wanted me to drop em in his garage …lol… yeh right … kerbside only for that bellend.
look out for overhead cables when operating crane and setting up, always extend ya legs out fully , i usually just drop the legs down on the side that i’m off loading to …as most instances i’m off loading in narrow streets and tight spots where i cant retract both out.
always put pads down under your legs feet, bewary of sinking tarmac drives especially when craning with full boom extended with heavy loads.
its up to you if you squash the bulk bags or hook em on the grabs ( some companys insist on the bags being hooked on, others dont ), personally i squash em midway with the grabs near the bottom and drop em quick , i used to hook em on before… till i had one bag split from the seams while trying to lift it off the bed and making one hell of a mess on the back of the wagon ( some yardie at the builders merchant decided to throw 30 bricks in the bag and three 25kg bags of cement on top into the bulk bag already containing 1 tonne of shingles , without telling me).
always grabs the bricks at the bottom from the short side and make sure the grabs are square-on on each side.
moving slabs/paving stones/toplite light weight building blocks usually come on small pallets ,if possible grab from the pallet if their sturdy enough with full length wooden battens that run all along the pallet.if not sling em off , dont squash the paving/slabs with the grabs as they will crack em or damage em which the customer wont appreciate. make sure their properly wrapped , no loose slabs lying on top of packs, if their are shrink wrap em on before moving them around.
Most important of all ----- try not to fall of the back of the wagon whilst trying to feed slings thru a pallet and hooking em on to the grabs, in the wet with the sides down— it does hurt .
plasterboard pallets make sure their loaded , with a gap so u can sling em, as most of the time the forkies just push em together on the bed , with gypsum boards i always sling em off, as most of them always come on crappy pallets that will fall to bits once you’ve attempted to pick them with the grabs
p.s always strap down your load … blocks , pallets , everything as they do move around .
