Investing in the right piece of kit pays dividends.
youtube.com/watch?v=xhY8TegMMZM
Good vid that, good point as well about investment.
Amazing
when are Jenkinsons getting some
Dream on!!
What is the road weight limit over there? I noticed that load was 60t.
Nice bit of kit.
I wonder how many times drivers have caught it on tree branches when pulling away when the body is tipped up?
Impressive was not expecting that !
good idea but looks a bit flimsy
As someone that pulls side tip trailers (well my first trailer is ) and my rear is an end dump (at the moment).
Im on aggregates so the sides are no so high as chip work but the problems come when you have to unload the front trailer ,you unload rear first for ya want to keep weight on your drives,you have to angle the unit so that when the load starts to slide out you can keep moving without your trailer wheels running into /onto the the load (on the ground) . This can cause you to lose drive and or if you try to run over the load roll you over .
AS shown in the video he can move wi the sides up…but unfortunately for me my system is …gearbox in 5th… neutral switch in .then pto in …then play the levers …making sure ive picked the right trailer button,and droped air(opens selected trailer door)… so when the load starts to slide whack it into 2nd ,neutral switch out and move carefully forwards.round the yard an do it again for the front body.
jimmy.
SwedishSteel:
Big industry makes its own rules in Sweden144ton tipper
I wonder what the rate is.
SwedishSteel:
540hp did I hear right
