Test point question
I’m looking at sorting out an “emergency” tyre pumper-upper/airline kit to run from the air supply and am wondering what size thread the test point connector is. Are they standardly generic on all lorries?
FWIW, I drive a3-axle rigid Axor and the test point is by the air tanks under the battery box, behind the n/s corner of the sleeper. Don’t know if that’s the standard position for Axors, the body builders may have moved things when they fitted the front-mounted Hiab?
Thankly dankly.
We have connectors that connect to the red airline on the truck and length of hose long enough to the rear of the trailer.
It’s not a bodge job it’s a proper piece of kit i can find out for you where we get ours from if you want!
tango boy:
Except he drives a rigid which doesn’t have suzie lines hence using the test point.
tango boy:
he’s got a rigid though!
just take it down to your local pirtek or equivalent, do it outside, chances are they’ll have what you need
You said
tango boy:
But he said
threewheelsonmywagon:
Think he will struggle to find the red air line :laughing:
Edit:Great minds think alike :smiley:
OP we have such devices on our forest fire vehicles. Next time I am at the station I could take a look and see what make they are.
Yep just read it again :unamused: Me bad lol :laughing: :laughing:
Sorry!!! :blush:
Test point should be a standard union. Machine Mart do 50ft lengths of coily airline and adapters to make your own up. £20 should see you sorted.
Merc used to supply an airline with the standard tool kit. Don’t know if they still do, but maybe worth having a chat to your fitters or have a rake round in the workshop.
