Evil8Beezle:
But ADR is not the issue, it’s the fact that a Newbie can enter the industry with no training about securing a load!
Not true: I had to do the Module 2 and Module 4 tests because I started after the requirement came in. I had to demonstrate that I could use a ratchet strap, internal strap and a rope and dolly knot to secure a load. I was also briefly trained on chaining a load but you only have to show three of the four on a test rig when you go for your practical test.
Now I can ratchet strap and internal strap with the best of them. I’m not too bad with chains either. I couldn’t tie a dolly knot to save my life because I learned it to pass a test four years ago and haven’t needed it since.
I’m clearing my CPC requirement until 2021 this week and because I move a number of different types of load, I’ve done flatbeds, tauts, walking floors, boxes, reefers et al during my four years, I have chosen to do one day on loading and restraining loads. It is a ballsache and it is creative paperwork, but if I have to do it I may as well get the most benefit from it I can.
desypete:
another modern day cpc card automatic moron driver showing there skills, i wonder which one of you guys will be next to over turn one ? there is no way anything can cut you up or force you to turn over on a roundabout as you would be going to slow unless of course you dont have the brains to understand it, well i guess there is one good thing to come out of it, at least he might learn how to slow down from now on
That could also be a problem of CPC training. In one module we are told to slow the hell down at roundabouts and tight corners to prevent the risk of accident. In another we are told how strapping this and securing that eliminates the risk of rollover. In the eco-driving module we are told to maintain momentum where possible for economy and to reduce the wear on mechanical components. Three CPC modules, all government approved, all contradicting each other.
I would slow down at a roundabout or tight corner to be sure. 1) I’m the one in the driving seat so I’m the one going to get hurt if it goes wrong. 2) Straps are all well and good, but there is always a chance that a strap can break, or the pallet can shift inside its shrink wrap or corrosion to the trailer can weaken the strapping points. I could do everything right and it still go wrong. 3) A gallon of diesel is a lot cheaper for the company that a recovery job, repair job or at worst case, a new truck.
nomiS36:
Our driver trainer has done just about every job going…he says [emoji57] Occasionally we get agency drivers that know him from a previous job he was at and a few have said he was taken off the road and put yard shunting because he kept hitting things [emoji1] another case of knowing it on paper but can’t actually do it.
There is nothing wrong with that. I used to be an army cadet and trained three consecutive county marksmanship champions in principals of marksmanship and skill at arms. I couldn’t hit a barn door at 20 paces with a sniper rifle, but I know how it should be done and could communicate that.
