Tanker work food products
is there any where i can find out if there are any subcontracted work out there?
Dev2
Sitra take on subbies.
sitra-group.com/nl/home-1.htm
thanks harry just starting out i want to be specialist and need all help
dev2:
Armet in Liverpool use subbies but you’ll need pumping gear on your unit & some knowledge of the industry & the right paperwork (O licence & all the correct insurances) before they’ll even considder taking you on, & that’s if they need any more subbies at the minute.
Good luck, Ross.
sitra-group.com/nl/home-1.htm these take subs on as well
what about what was atchinson topeka now bibby i think
I think Liquid Logistics are looking for a new subbie, not allowed to say why though (but it does apparently involve L.L ‘forgetting’ something)
Derf:
whats Robert messed up now then
sitra do take on subbies it will be worth a call as they have some trailers fitted with electric pumps, having said that i would imagine they will want you to get a hydraulic pump/compressor fitted to your motor as soon asap .
also check the rates as they never use to pay empty running.
Agri Energy in Liverpool could also throw you some work. Ask for Ian Sinclair
Why not give Norbert Dentressangle Leigh depot a call they use subbies, you will need pumping gear
