Conor:
tachograph:
To comply with the WTD regulations he would need to have a break of 15 minutes before or immediately after a total of 6 hours work, so yes he could drive for a further 1.5 hours, but he would only need to have a 15 minute break at this timeROFL. I’m not going to take any advice from someone who thinks that it’s a 15 minute break for going over 6 hours work. Here’s a hint - go do some reading. You’ll find several things out including what the breaks are to comply with the WTD and that for the purposes of the drivers hours laws, the week is set, not dependent on when you put your first chart in after taking a weekly rest.
For WTD purposes if you work between 6 and 9 hours in a shift you should have a break of no less than 30 minutes, this is not the same as the 6 hour rule which states that you should not work for more than 6 hours without taking a break.
The length of break for the 6 hour rule is not defined in the regulations, therefore it’s generally assumed to be the minimum permissible break which is 15 minutes.
If you work between 6 and 9 hours you would need to have another 15 minute break before the end of the shift, making a total of 30 minutes.
If you work more than 9 hours you would need to have one or two more breaks of no less than 15 minutes each, totalling no less than 30 minutes, making 45 minutes in total
In either case you should not work for more than 6 hours without a break of no less than 15 minutes.
This is to comply with the WTD regulations and does not take into account the driving breaks, although the WTD breaks do count towards the driving breaks as long as they comply with the driving regulations and vice versa.
The Regulations require that:
- mobile workers must not work more than 6 consecutive hours without taking a break,
- if your working hours total between 6 and 9 hours, working time should be interrupted by a break or breaks totalling at least 30 minutes,
- if your working hours total more than 9 hours, working time should be interrupted by a break or breaks totalling at least 45 minutes,
- breaks should be of at least 15 minutes duration.
