Hi, is there a way to see how much poa and breaks I have taken in the day on a tacho unit without having to use half a roll of tacho paper?
Or is it a case of making a note of times in a diary etc (which I have been doing anyway)?
Cheers!
Yep. Press the up arrow, you will then get the prompt “call main menu?” Press ok, then press up arrow 3 times until the prompt “display driver 1” appears, press ok, press ok for “24hr day” the date that then appears will be the current date, if that is the day you want press ok again then use the down arrow to scroll through.
Sounds complicated, it isn’t. Plus you don’t end up looking like a badly wrapped Christmas pressie with all the generated paper!
