Tacho Question
left card in tacho today and wont be able to take it out till tomorrow 11am from 05.30 this morning what will rules be regarding this any advice appreciated
WTD and insufficient breaks?
Possible insufficient weekly rest depending when your back on.
The pro’s will give you more.
Probably just need to print out and write on the back
Then carry on with your weekend
parked up at 2pm this afternoon and not back on till 6am monday
If you left the tacho on rest then it’s no problem at all, mine stays in for weeks at a time, if you left the tacho on other work or POA then you need to do two print-outs, one for each day, and write on them you made a mode switch error and that you started a rest period at 0530 23/11/2012, then sign and date them.
Harry Monk:
If you left the tacho on rest then it’s no problem at all, mine stays in for weeks at a time, if you left the tacho on other work or POA then you need to do two print-outs, one for each day, and write on them you made a mode switch error and that you started a rest period at 1100 23/11/2012, then sign and date them.
thanks its on other work i totally forgot about it :unamused:
Happens quite a lot from what I have read - its called human error and does not surprise VOSA when they come across it
Don’t go to France or Spain for the next month and you will be fine :stuck_out_tongue: If you do go you will be fined :stuck_out_tongue:
Do 2 printouts, sign and state that you are a silly sausage will suffice for VOSA
