Good evening all hope you are well,
Just a quick question, when I do printout at the end of the day the printout still has error codes on from 2015. I recognise a couple as power failures, one where I left my laptop on all night and the battery went flat, the other is where I had problems with the wagon starting and disconnected the battery while my card was in. Surely after nearly two years these error messages should not be showing up on my printout?
I’ve got similar ones on mine, it’s like that since 2014.
Sounds like your on a dvsa “watchlist”.
They do this with drivers they are suspicious of. When your battery ran flat, it triggers an alarm that flags your card and keeps the error codes so the guys at the checkpoint know you are one ot be watched and scrutinised more throughly. A guy in an RDC told me this was what they were doing now and he had no reason to make anything up. He seemed to know what he was doing.
I think your best bet is pour some petrol in the cab and set it alight and then burn your card in a seperate, discreet location before changing your name and moving your family to the other end of the country
The-Snowman:
I’d rather go to prison!
Or maybe Syria…
The-Snowman:
just tell them you are a refugee. you will get all the benfits for nothing
Darrenb:
The last 5 events or faults on the driver card are shown near the bottom of the printout, beneath them are the last 5 events or faults on the tachograph.
You’re card has been cloned. There is now an Irish boat chaser doing 80 mph up the A75 on his way to Barcelona for a Monday 10o’clock. .
