Tacho manual entry
Last night when I got to work the truck had an air leak so I was sent out in a 3.5t flatbed. Do I need to enter these as a manual entry ■■
I would but then I manual entry everything even training courses.
Thanks toonsy
You can always put one of these…?
Miketyres:
You can record the work on a printout or chart or log-sheet which I assume you was using.
Personally I wouldn’t manually enter it into the tachograph, there’s no point.
If you do this use the ? symbol to record the time from when the card was last ejected.
