The Soulman:
Ok guys, first thing, I hope I’m posting in the correct section.
My question is with regard to making a manual entry to record rest from when I last withdrew my card to the start of my next shift.
The fleet where I have been working as an agency driver for some time now are all 62 plates and as such have the newest VDO tacho heads fitted, I find the process for recording any activity between the period the digi card was last ejected and the time it is re-inserted is very simple and straighforward.
My question relates to the tacho head units that initially display “End of shift” when OK is selected when asked if a manual entry is required.
I was recently using a slightly older DAF that had been hired in and that had one of the less recent tacho head units fitted.
I went through the process (Or thought I had) of recording the period between last ejecting to re-inserting my card as rest, however when I downloaded the data onto my digi tacho software (Globofleet) the period was displayed as “Unknown”
I had evidently made some cockup somewhere along the line and would appreciate if one of you kind gents (Or ladies) could give me a step by step / idiots guide to completing this process successfully.
Thank you and regards in advance, The Soulman.
As you know on new type digital tachographs when you do a manual entry you input the times of all activities including the daily rest period since withdrawing the card on the previous shift.
However on the older type digital tachographs you do not need to input the daily rest period as a manual entry.
Lets say you withdraw the card at 17:00 and finish work at 17:30 with the time from 17:00 to 17:30 being other work.
On the old type digital tachographs when you press “yes” to do a manual entry the tachograph display will show the time the card was withdrawn in our case 17:00, you then change the time to 17:30 and the activity to other work and press “OK”.
The display will then say “End of shift” (or something like that) and you press “OK” to end that previous shift, select the country the shift ended in and press “OK” again.
The display will now show the time you inserted the card and ask “begin” and you use the arrow keys to change the time to the time your shift started, then change the activity to suit.
On the old type digital tachographs the time between shifts is assumed to be a rest period, you don’t need to put the daily rest period in.
You can try it for yourself on the tachograph simulator here
By the way, I’m not familiar with Globofleet but you shouldn’t need an accurate record of your daily rest periods in order to have an accurate record of your working hours, if you’ve recorded the working hours that should be all you need
