Tacho fault
Drove down to Kent this morning and 3 times tacho has flashed sensor fault, is there anything I can do to fix it or is it a tacho centre job, thanks in advance
Tacho centre job as it may involve changing the sensor on the gearbox which has a seal on it you can’t break or replace unless you’re an authorised service centre.
