Tacho card - probably a silly question
Hi all
I am due to start my first tramping job tomorrow and I was just wondering about my card. Is it normal to leave it in the reader for the whole week or to pop the card when you finish for the day
If I am going to leave my card in then I need to remind myself to switch it to break
I realise the answer is obvious if you know it but thought I would check anyway
Thanks
Some leave them in and some don’ t. My preference was always to remove my card at the end of my shift and then pop back in the following morning.
Sent from my SM-G925F using Tapatalk
Its personal choice really.
If you leave it in all week, you will have less wear and tear on the card, and also on the unit itself. The downside is you need to remember to put it on rest at the end of the shift. Another possibility is that you are assigned a truck that defaults to other work whenever you turn the ignition on, meaning you could mess your rest up by accident by wanting to open a window, or trying to turn on the radio.
If you take it out, you have to remember to put it back in each morning!
My preference would be to take it out, as I’m a forgetful sod, and would be checking the bloody machine every five minutes to make sure its still on rest, instead of actually resting!
take it out.
Oh and there is no silly questions; only silly people answering questions stupidly!
Ask away, it’s what this forum is for.
I’ve always taken my driver card out but as has been said it’s a matter of personal choice.
If you leave the card in you need to manually enter the shift end location at the end of the shift and the shift start location at the start of the next shift.
Always removed it, then theres no way of incidently leaving it on Other Work.
I leave mine in all week…But do you really need to input the end location in when you finish your shift & start it again?..As the only option is Uk…Used to change the country when doing europe of course…But just on Uk work now and wondered if you would actually get done for that…
Sent from my SM-G920F using Tapatalk
daftvader:
The only option is UK :confused:
I’ve no idea how serious the DVSA regard not entering the country symbols or if they would do anyone for it, however there is a possible £50 fixed penalty for the offence.
Thanks for the quick responses.
I will be taking it out as I’ve a rotten memory and the answer about checking the unit every 5 mins struck a chord with me as I do it already during the 45 mins break
I hadn’t thought about the UK answer as will be doing European trips soon and it hadn’t occurred to me. Will have to check that one with the employer and see what they prefer
Thanks again
Cate
My driving experience pre-dates digital. But when I was tramping I used to tuck the keys inside the box of new charts so I remembered to use a new chart. Similar principle and it worked for me.
Pete :laughing: :laughing:
good_friend:
Thanks again
Cate
Well if your going onto european work you wil need to enter start and finish country locations…And if doing spain i think you have to enter the region too…Only done spain twice though…And can’t remember what i entered for that.
