I start my first driving job next Monday and I have a fair idea how driving hours work but can someone explain it a bit better lol
So I know 4.5 hours driving you need 45 min break
3 hours work + 3 hours driving you need 30mins
So what if I have local multi drops, do I drive to each place, set my tacho to ‘other work’ while I open the curtains to get unloaded and then count that unloading time towards my ‘other work’■■
So if I do like 2.5 hours other work Nd 2.5 hours drive then I decide to have a 30 min break, that will reset my times so I can do them all
Over again?
Buy two kitchen timers from a hardware shop or cooking shop.Salter is the brand.
Set one timer for the tacho and driving hours the other for Wtd.If you write it all down it gets confusing and you need to concentrste on driving not scribbling notes down.
There is no time for that.
toby1234abc:
An easier way is most vehicles now have digi tachos. It will show your accumulated drive time. Don’t exceed the 4.5 hours without a break.
Whatever your start time is, add 6 hours and make sure you have a break before that time.
Most places don’t pay your 45 minutes so take it all in one go after about 5 hours. By the time you’ve finished your break you’ve reset all your working times and if you’re doing pallet network multidrop it should leave you enough time to complete your day without any other breaks.
Wtd is other work and driving.For example start work at 7 am and by 13.00 that is six hours.So need 30 min break for Wtd.
But for driving its 45 min break if driven 4.30 hours.
Most of us would take a 45 min break by 13.00.
Then wipes the slate clean for more collections or drops to do.
When select the Poa mode it stops the timer for Wtd.
Just stop at the six hour point.If you work over 9 hours another Wtd break is due.
toby1234abc:
toby1234abc:
As has been said, unless there’s a company policy to have 30 minute break before exceeding 6 hours working time, you need a 15 minute break to satify the regulations not 30 minutes.
Also if you work over 9 hours you don’t necessarily need another break.
m1cks:
Can I borrow your brick wall please Tachograph?
Another example of the current newbie system not working as it could be
We now have a newbie who has the licence, knows how to do vehicle checks and how to search for drugs and illegals but is not trained and tested on the regulations
It really needs module 2 to become a test on the regs
Agreed rog, I think they should of put some of the driving hours etc in with the test or whatever.
It’s the most confusing part yet the less concentrated part in all the training
