T range TV mount
Has any one fitted one of these in to a t range if so how and where
kudauk.ltd.uk/product/incab … ialbracket
Thanks for any info
Hi Taz…tell you what i did …go to B&Q…pick up one of those glass carriers…like a bath handle with a sucker on each end ( with a lock down catch ) make sure you buy the nuts and bolts as well…i used a sat dish and a sky box
anyway, secure the Bracket to the handle of the glass carrier, even drilling a hole if needed or two…then the bracket will stick to the front of the vehicle or the windscreen as and when needed via the suction pads ( a little water helps or glass cleaner in a spray bottle ) then once in position lock down the handles and thats it. just run the cable through the n./s window…let us know how you get on…
that deal looks quite good…i paid £500 for the tv, which had built a in sattelite receiver…only good for the uk though ( hence the big dish i needed for europe ) and i paid £54 for an indoor aerial…this was convenient for uk work, as i only used the dish when abroad to get uk tv…like the eastern bloc drivers use for their home countries tv.
Ok thanks for the info
Cheers
