I always thought your start of shift checks were just advisory, and also good practise
On a CPC module the other day, I was informed that VOSA hand out quite hefty fines if you haven’t started your shift with your tacho on hammers for 10 to 15 minutes
espresso:
Is it really fineable ■■?
i got same truck every day just now (52 plate) do my checks in less than 5 minutes
walk up no leaks or flat tyres, tacho in check oil water
quick walk round check lights and any damage
same with trailer
from previous threads i think you need show a suitable time
Since I’m fed-up being a sick-note off other’s bugs/pickings/mucous/scratchings/itch-meat, etc, a pre-use anti-bac’ pantomime blitz of cab surfaces with a fresh cloth daily takes me a coupla minutes
It doesn’t need to be 15 mins to the absolute second as Andy notes, but should something happen during the day that a normal daily check would have uncovered and prevented, the book will get thrown and rightly so.
As with all things transport the job takes as long as it takes, takes me more than 15 mins to check my whole vehicle, paperwork, seals etc…the driver is responsible, end of.
I used to do agency work for a company that you had to show 20mins work at the beginning and end of your shift ( lead in and lead out times ) and every time you did a trailer swap !!
I’ve found (and I could be wrong) that when greated with a dirty water header bottle theres nowt else for it than to gently (and I mean gently if its a hot engine) unscrew the cap on the tank and dip ones pinky in, usually about half way up is where the ‘Max’ line is so if ones pinky feels hot or at least a bit moist the water level is ok- if one has to use a longer pink tipped appendage (make up your own jokes here) then a top up maybe needed.
Just my experience others may chose alternative body parts to test the depth and moistness…
espresso:
same with trailer
this 15 minute malarkey is usually company policy
i would have asked him to either put up or shut up, by telling him to show me the relevant law in writing
there is no definitive time set by any governing body as to how long the daily walk around check must take
all these who say, “my place insist on 15 minutes for the truck and 15 minutes for the trailer”, that will be company policy, NOT law
even on the VOSA (as was) DVD for the drivers hours, the VOSA (as was) man states that if you have the same truck and the same trailer every day, and nobody else drives it, then the walk around check can “be done in a couple of minutes”
Just as well this isn’t the good ol’ US of A. It seems that to pass the equivalent of the HGV test trainee drivers need to be able to know and demonstrate the following:
The Guide To Maintaining Roadworthiness states the vehicle must be checked by a responsible person before it is used and at least once in every 24h period.
Nowhere does it state the DRIVER has to check it at the beginning of his shift and no times are stated.
It would be perfectly resonable to get your vehicle, 5mins to check oils and water, stick your card in, drive around the yard to your trailer, couple and then do your full checks … would that make DVSA get all excited because it wasn’t at the start of my shift and wasn’t 15 minutes ?
There is a “Failure to record a walk round check” listed in the Enforcement Sanctions Policy but this is for failing to record the time spent as work rather than not doing a check. The result is a Verbal Warning anyway.
I give mine a good check over every night if there’s something wrong or I’ve picked up a puncture I’d rather mess about at night than ■■■■ around in the morning so my checks take all of 5 minutes in the morning oil water lights horn and a quick check again of tyres. My tacho shows a good 10-15 minutes every night and a bit in the morning I drive the same vehicle everyday so if there’s something a miss ill notice it.
Whilst a good organised driver can do the walk around checks in five minutes, I doubt if VOSA would consider that enough time if they then find a defect when they do their walk around checks at the roadside.
As we all know there is no arguing with VOSA… They are right and truck drivers are just a source of easy revenue…
