So I’m with a buddy driver tonight, gona split driving… so basically would this be allowed; from London he does 1 hour to services, 15 min break, I take over n do the rest to say Leeds, we have 30 min break, I then do 1 hour back down to services, 15 min break, he takes over does the rest to London… am I [we] allowed to break it up like this (however we want) or does it totally not work like that…? Cheers
You need to have driven before you can take a break that will could towards your driving break,any break taken before you have actually done any driving won’t count towards your driving break.
You could literally drive for 5 mins then take a break and it will count towards your driving break but if you didn’t drive at all the had 15 mins break then drove for 3hrs then had 30 mins then drive another 1h31 you’d get an infringement.
Ok, so would this be ok… He does 1 hour, 15 min break, I do 4.5 driving, 45 min break, I do 1 hour, 15 min break, he does 4.5 driving, finish…? I’m guessing no because his or my 15 min break it will ‘ask’ why didn’t he/me finish the last 3.5 hours…?
Dnspring64:
Sent from my SM-N910F using Tapatalk
That’s fine,you don’t have to run to 4.5hrs to reset your driving time it’s the break that resets your driving time not the driving time itself so the above is ok.
I am assuming you will both be together within the first hour of the shift starting so will be under MM rules using slots 1 and 2 of the digi tacho
That being the case then this is legal if both drivers have a 10 hour driving shift available
D1 = driving for 2 hours with D2 in slot 2 on POA
Change over quickly
D2 now driving for 2 hours with D1 in slot 2 on POA where first 45 mins is deemed as break so 4.5 driving time is reset
Change over quickly
D1 now driving for 2 hours with D2 in slot 2 on POA where first 45 mins is deemed as break so 4.5 driving time is reset
Change over quickly
Change over quickly
Change over quickly
Change over quickly
Change over quickly
Change over quickly
Change over quickly
ROG:
Change over quickly
Change over quickly
Change over quickly
Change over quickly
Change over quickly
Change over quickly
Change over quickly
Change over quickly
Change over quickly D2 now driving for 2 hours with D1 in slot 2 on POA where first 45 mins is deemed as break so 4.5 driving time is reset
FTFY
It’s legal but I’ve no idea why anyone would want to do that.
Nobby_Clarke:
It seems an easy job made hard to me. Why doesn’t the first driver just do 4.5hrs or whatever to save keep poncing about swapping the cards over
Maybe because the place they are going is 5 hours away and they want to have their break when they get there…or something like that
Nobby_Clarke:
