With all this sunshine - my right arm is going browner than t’other
What do I do?
Put suntan lotion on my right arm but not my left?
Cut the left sleeve off a long-sleeved shirt?
Get a left-hand drive truck for sunny days?
Any ideas? I can’t have this - I have an image to consider.
              Renault Premiums now have air con.(Comment expected from Rob K,  )
Ken.
              Get a Renault and use the money saved to double man meaning you can swap between the drivers and passenger seat.
              Lostpup, this is really quite simple. Let the window arm go brown in the sun…and use false tanning gel on the other. Job done. x
              Had the shorts out this week — also crossed my mind about getting burnt/tanned on the top of the legs, with a white stripe where the steering wheel creates a shadow!
In the summer of ’99, I had a plaster cast on my left arm up to my elbow. When it came off, not was it very white, it was also a hell of a lot skinnier than the right!
              Drive one of them sweeper trucks with the twin steering wheels,and change sides every hour
              Lostpup,
I posted a suggestion on this very subject earlier this week:
trucknetuk.com/phpBB2/viewtopic.php?t=3474
My contribution is about threequarters of the way down the page.
Better than skincancer anyday.
              Temporary sleeve. I like that.
              Wear your drivers arm with pride!
              The answer to your problem… Try working nights. Failing that, have you thought about gravy browning on your left arm
              would the gravy browning not give you a yearning for some roast beef with all the trimmings?
              MMMMMMmmmmmmmmmmmmmmmmmmmmm
