Senior Moment (Bloody Stonebridge Tacho)
Why ? why ? why ? do Stonebridge (referred to as Knobbridge from now on) change to default ‘Other Work’ when you switch the ignition on. Had the motor for 8 months now & the Knobbridge Tachograph still keeps catching me out, took a 15 yesterday followed by a 30 an hour later, checked the time by switching the ignition on & it said 29 minutes but defaulted to Other Work so I pressed the 1 button & didn’t notice that it hadn’t changed back to break ! Durrrrrrr.
So now I’ve got yet another infringement that I’ve had to ‘Self Bollock Myself’ with by writing out an Infringement Reporting Form, so I don’t get a little letter telling me off for being a Naughty Boy.
What a load of Old Bollox all this is, I’d had over an hour on POA just before I took the 30 minutes Break, but as we don’t get paid for breaks, I keep the Break Mode to a minimum, so I’ve Technically Broken the Law by 1 minute [emoji22]
Throw away the key & leave me to Rot in Infringement Hell [emoji12]
■■■■■■■ hell martin. I’d say that’s not going far enough really. I think you should offer to rip you own toenails out and lube ■■■■ with a thistle too…
:laughing:
I take it your tacho isn’t wired so that the light on the tacho screen comes on when you push “ok” with the key out of the ignition?
F-reds:
[zb] hell martin. I’d say that’s not going far enough really. I think you should offer to rip you own toenails out and lube ■■■■ with a thistle too…
:laughing:
Yea it does Fred, but what ■■■■■■ me off is the fact that you’ve got buttons above your head & the ignition switch as well & I’m not getting any younger, with a tendency to forget stuff & go off on a tangent-----------------
Oh Bolox, what was I on about [emoji57]
I have never actually tried it but I believe some Stoneridge models allow the user to set the auto-mode activities when the company card is inserted.
Perhaps this is worth investigating as you could stop it doing it.
Unfortunate name that - Stoneridge - brings up immediate images of Fred Flintstone, Dino and the quarry! :smiley:
Our stonrridge got to break when ignition is turned off.
cav551:
There you go, another Senior moment, I’m even calling it StoneBridge !
shep532:
I had it changed from Break to Other Work when I first got the wagon, it defaults to whatever you tell it, our lot pay us off the Digicard & deduct ALL Breaks, first day out I clocked up about 7 hours of Break (every time I switched off) [emoji57] & had to explain why I’d been asleep most of the day. Lol.
Come back Siemens, all is forgiven. [emoji106]
It’s a 5 min job at a centre to get it to default to what you want…Unfortunately no one can second guess what an owner wants/driver wants unless specified at PDI …If not specified it will be left on what ever it left the manufacturer on
martinviking:
shep532:
Rather than have it set to default to Break or Other Work when you switch on/off (neither of which appear to be ideal for you), why not have it set so it stays on whatever mode was already active? Pretty sure a tacho centre can do this.
Don’t mention the word Stoneridge, i still get the willies just thinking about the hopeless things that were fitted by default to every bloomin Scania at one time, was as much as i could do to get me card out at all, let alone consider doing anything like a manual entry.
How did something so utterly unusable by the typical age group of regular drivers ever get the green light, beggars belief.
Nothing that a gallon of diesel and a big box of matches can’t fix
i like the new ones , easy to use and understand.
spot on for keepin track of drive time etc.
gezt:
Had one in my last puddle jumper, thought it was great, other than a proper eject button, it was perfect. No bloody waiting and faffing and writing down times etc
Juddian:
Our CPC trainer (in-house) told us a Stonerigdge rep admitted that they got the manual entry interface badly wrong on the first version of their digital tachos.
The newer ones are much better - big symbols and a layout that makes it clear exactly what you are doing - and I would would much rather use the one in my current truck than an VDO tachos I’ve used.
