Hi guys. I am looking around on the dash for a valve to connect an air duster. No joy as yet, any ideas?
Sent from my TA-1024 using Tapatalk
Been a while since I drove a Scanny but something is telling me that there’s a blank around the handbrake that can be pulled off and there’s an air point behind it.
Probably misremembering tbh.
Yer memory is sound Maoster, the cover is about 2" wide by maybe 3/4" high and flicks off easy with a screwdriver.
the maoster:
Been a while since I drove a Scanny but something is telling me that there’s a blank around the handbrake that can be pulled off and there’s an air point behind it.Probably misremembering tbh.
Maybe been modified then…
Thanks for the help [emoji1303]
Juddian:
I’ve pulled off the little blank with the blue push button fitted (see pic) no joy…
In that case you may need to visit your workshop and “borrow” one of them plastic push on T pieces for joining airlines, cut the feed to your air seat and attach it there. If you’ve never done that before it sounds daunting but if an idiot like me can do it in under a minute then anyone can. Good luck.
Will do, cheers
tamsmiff77:
Juddian:
Yer memory is sound Maoster, the cover is about 2" wide by maybe 3/4" high and flicks off easy with a screwdriver.I’ve pulled off the little blank with the blue push button fitted (see pic) no joy…
Bugger, must have changed things on the ones that come with satan’s poxy electric park brake, sorry mate ![]()
Remove cover highlighted.
Or use a t-peice and cut into seat air, behind the grey kick panel on front of seat, just pulls off, revealing the seat air line.
Yeah, had a look behind there, there’s a gap, but no connector. I’ll get a t piece next. I’m thinking 8mm? Thanks
