Scania P220 Night Heater questions
Morning all,
On the night heater , it throws heat out from behind the drivers seat but at the passenger seat , the outlet only throws cold air out.
Should both of them not throw out warm air ?
Also how do you change the time on the remote control as its showing an hour behind due to the clocks going forward an hour.
With the engine turned off and engine cold the ordinary cab vents throw out cold air, is it possible to shut off all these vents as u can only seem to switch between top middle or bottom on the dial on the dashboard , cant see anything to shut them all off
Lifted the bed, found the night heater itself
on one end of the heater the ducting goes to the drivers side vent , on the other side the ducting goes to the passenger side vent, on opening the heater itself it seems on the passenger side there is a fan just where the ducting connects to the heater and this is whats throwing out the cold air for the passenger side,
Is this normal ?
Nope not normal should be hot from both
That’s not a night heater problem. THIS is a night heater problem. :smiley:
This works…
youtube.com/watch?v=3UExpnBJ2bM
Passenger side is the inlet, maybe feel like its cold air coming out but trust me its going in, setting the clock hold the centre button with the arrows on and the clock button at the same time
blue estate:
It shouldn’t be hot from both sides the opening on the passenger side is the air intake for the heater. To change the clock on the remote it should display the same time as on the dash which is adjusted sing the 4 wee buttons just to the left of the steering column, if the two displays continue to be different then there is a problem with the remote
Harry Monk:
Lol mine does that for it’s 5 minutes, great after that just need to make the windows are up before firing it up.
Thanks everyone,
Got the time on it changed from the buttons on the steering wheel,
Disconnected the cold air intake but must connect it back up now If its feeding the heater with cold air :slight_smile:
