as above does anybody know what fault code 51,52 and 53 mean?
Angus
Angus
Injector faults - 5 = injector the no after is which injector has the fault - looks like you need 3 mate
guess thats why she wont fire then lol
wee_gus:
Don’t automatically assume it’s the injectors themselves at fault! I had a similar problem with an MP1 Actros, the ECU was reporting a faulty injector but when I swapped them around it was still claiming the same injector was knacked.
Turned out to be a corroded wire which had been chaffing against a bracket, and was only visible once the insulation was stripped back.
Yes, Scania p114 is a fault.
